RE: Top Flite Giant P-47 Build
Don't know if the TF Kit built is that much different than the ARF but my ARF balances perfectly at the 6-3/8" 162mm from the leading edge, with a Magneto G-62 installed so the prop hub is 6-3/4" 171 mm from the firewall. No tail or nose weight needed. Did put 2 25ooMAH LIFE batteries way in the back and had to move one battery up between the elevator servos to get it to balance.
