RE: 30cc Edge 540 build
Greetings from La Paz Mr. Towers !!
I can bet 10 to 1 that you may be able to hover it; just use a 22x10 prop (better if you can use 23x8), by the way; how is that you solved using that kind of diameter prop ? did you change the stock landing gears? and please what is the final weight (dry) of your airplane. Happens that I will be using same plane with an OS 55 GT
Please keep us posted
