RE: How does a gas engine act when hot?
Some of the DR1s had larger holes in the cowl, and, is thier any way you can open up the bottom at the area between the landing gear, to let more of the cooling air out? You might try running the engine without the cowl and see how it does. As an aside, have you got the CG set yet?
