RCU Forums - View Single Post - Servo setup
Thread: Servo setup
Old 07-24-2013 | 07:41 AM
rlipsett
Default RE: Servo setup
get hi tech programmable servos and the programmer. reverse the direction of one servo then match the same center and endpoints using the programmer. After this is done you can use a y connector to connect both servos to the same channel and they will be in sync
