Vectored thrust set up on 18mz
I have a skymaster turbine Mig-29. Two vectored thrust nozzles, two servos each. I have rudder and elevator set up and just made a condition to zero the ATV in normal flight mode. I have two servos assigned as nozzle 1 and two as nozzle 2. I would like to mix in ailerons as well. I'm guessing I have to split them into 1-4 in order to mix in ailerons? Will that take 6 separate mixes? Can I assign two channels as slave in a mix?
No y-connectors, sbus channels 12-16.
