RE: RC Guys Cessna 150 Aerobat Gas to Electric Conversion
RCNUTKNOY,
Thank you very much for your reply. Could I ask you to explain, or possibly post some pics of how you mounted the motor and ESC? I am trying to mount them both in the front (on the firewall) and I am having a very hard time fitting them in there as a result of some beefing up I had done for the gear (I always felt it was a weak point).
I would also like to see how you mounted the batteries to achieve the proper CG? I just started the night before last and I removed the old engine, last night I started to mount the motor and ran into the problem I mentioned above. I am also wondering if the motor requires and right/ down thrust to be added as well?
Any direction or recommendation you can provide would be greatly appreciated.
Thank you again for your reply.
Regards,
Cesar
