RCU Forums - View Single Post - Engine mounts
Old 07-24-2013 | 03:34 PM
tailskid's Avatar
tailskid
My Feedback: (34)
Default RE: Engine mounts
What plane are you putting the engine on? Usually the thrust washer determines how close to the cowl opening should be....if you do not have a cowl on your plane, I like to put the engine right about in the middle of the mount (assuming that is OK with the CG).
