RE: Novice seeking advice
They are all "sticks". It's the design of the aircraft that makes us refer to it as a "stick". They all have good wing loading, usually well powered, and can handle in a wide range of mild and trainer like to wild and crazy, depending on the setup.
If that is your cup of tea, find one that you can buy at a reasonable price, build/assemble it and fly it. They are a lot of fun to fly. BUT, I would suggest you set it up to be somewhat sedate until you are used to it then dial it up a bit. You will know when to do so.
CGr.
