RE: Spektrum Dx4e,AR6100e with Tamiya DMD-T03
Hi I have a Spektrum DX4e and use it with Orange receiver's, have used it with spektrum receivers .It works fine with the SLU El-mod and Tamiya dmds .Just set it up in low rate as per the Tamiya instructions then switch to high rate ,you wont have to use the trims to fire the guns. At the moment I am using it in my LCM with a Tamiya T01 DMD. regards pete
