RE: ZIROLI 98
wings (cont)
3-piece conversion (cont)
center wing:
I cut the flap sheeting at rib W-6 so I could remove the outer wing.
Next, I dry fitted the 2 inner wing halves again to insure all fits properly.
Using a popsicle stick, I buttered a thin layer of epoxy on both surfaces of W-1 ribs. Since I had the top of one side sheeted, I had to first slide in the two top joiner spars. I cut a couple holes in the top sheeting (fuse will hide them) so I could clamp along the center of ribs W-1 as well as along all the sides of the ribs.
Last, I dry fitted the two outer wings to insure all is still aligned.
