RCU Forums - View Single Post - CA hinges to Robart pin hinge
Old 07-26-2013 | 04:15 AM
TomCrump's Avatar
TomCrump
Default RE: CA hinges to Robart pin hinge
ORIGINAL: bikerbc
I find that there is usually not enough backing for the Robart hinges so it requires opening up the covering and installing little blocks...Installed properly the CA hinges work fine...
I was thinking the same thing.
You can see the blocking for Robart Hinges in this pic.
