RCU Forums - View Single Post - How do you remove cup on front of starter?
Old 07-26-2013 | 08:57 AM
skeeter_ca's Avatar
skeeter_ca
Default How do you remove cup on front of starter?
I am installing a finer edge battery adapter on my Sullivan starter and ran into a problem. I have to reverse the main bolts that go through the starter but in order to do that i have to remove the aluminum cup on the front of the starter. i removed the nut inside the cup, but the cup still wont come off. I tried a gear puller on the cup but that didn't work. Is it screwed on? If so how do i get it off. How do i hold the shaft to break it loose?
skeeter
