RE: starters
I would suggest a spring starter for the 38, works very well at starting the engine cold, once warmed up between flights it should start easy with a sharp smack of the prop counrterclockwise, you have to intall the prop so compression starts at about 12oclock and then pull the prop back to 3-oclock and then fling it fast over the top.
