RCU Forums - View Single Post - Basic settings of YS 170
Old 07-30-2013 | 03:52 PM
drac1's Avatar
drac1
Default RE: Basic settings of YS 170
ORIGINAL: riot3d
ORIGINAL: Ekvien
In accordance to the manual the tappet clearance are only 0,002 mm!!! how could you be able to measured that clearence ?
I never use a feeler gauge, just by feel. Basically, no movement at TDC. I check them about 50 - 60 flights.
Adrian
If you can't feel any movement, then there isn't any clearance. Even with 0.002" (0.05mm) clearance, there is noticeable movement.
