RCU Forums - View Single Post - Judging 8 sided loop
Old 07-31-2013 | 02:25 AM
drac1's Avatar
drac1
Default RE: Judging 8 sided loop
ORIGINAL: rcprecision
Jim O
Assuming we are discussing the AMA Masters 8-side loop, the way the maneuver description is written the entry point is the first 1/8 loop before the first 45 degree line segment. The judging of the maneuver began albeit subjectively with the required straight-line between maneuvers which does not have a defined length, just that it must be demonstrated.
The exit is the completion of the 8th line segment which conceptually is where the maneuver began. The next maneuver can begin after a straight line is demonstrated. Again AMA rules do not define the length of the straight line between maneuvers just that it must be demonstrated.
If no straight line is observed a 2point downgrade is awarded to the upcoming maneuver.
The exception to this is entering or exiting the maneuvering area. The rules state a 15 meter (~50’) minimum straight line must occur prior to beginning of the first maneuver and completion of the final maneuver. This of course excludes take off and landing since they are not done within the maneuvering area.
There must be a straight line between all maneuvers. So if there is no straight line, shouldn't the downgrade be 1 point off the completed maneuver and 1 point off the upcoming maneuver?
