RCU Forums - View Single Post - Need suggestion on setting throws
Old 07-31-2013 | 07:07 AM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Need suggestion on setting throws
Whenever I setup a new plane I always set the control surfaces for the maximum that called for in the manual. Most manuals will also give you a low rate setting as well, which I also setup. You want to go with the max amount for the first flight because it's much better to have too much control throw and not need than it is to need control throw and not have it. If you take off and find that there is too much on the high rate setting you can switch to low rates so that you have less throw.<div>
</div><div>Hope this helps</div><div>
</div><div>Ken</div>
