RCU Forums - View Single Post - Epic Journey
Thread: Epic Journey
Old 07-31-2013 | 11:49 AM
  #66
MTK
Default RE: Epic Journey
ORIGINAL: JAS
Quick question: Which of these is stronger for a firewall (like for the Epic) and which is stronger for mounting plates for a motor (like for nose mounted motor), if there is a difference:
[link]http://dragonplate.com/ecart/product.asp?pID=3820&cID=75[/link]
[link]http://dragonplate.com/ecart/product.asp?pID=4926&cID=141[/link]
Yes there is a difference between thetwo but nothing worth noting for the intended task. The 1/8" thickness of the carbon sheet is the driver. Way overkill for the task, BTW. There's no reason to have that much thickness for a motor this small....Are you planning to remove most of the sheet? If yes, then 1/8" will be fine.
