RE: Distance judging
If you reflex the ailerons, you reduce the camber ... you reduce the lift co-efficient ... which means the wing has to fly either faster or at higher A of A to produce the same amount of lift.
How is that going to help you to get into a tight space?
And how come the designers of full-sized planes never thought of that?
