RE: Sig Spacewalker II 1/4 scale
All of the guide tubes have been trimmed off flush to the sides of the fuselage. You may note that I have added some balsa pieces to the sides in the rear tail section. This will provide support for the rear of the guide tubes as well as provide adequate surface area for the covering to attach. All of the pull-pull cables as well as the 4-40 rod for the elevator will be cut to fit during final assembly after paint. Next I need to install the fuel fill cap, then it's time for final sanding!
