RCU Forums - View Single Post - Evolution 15GX question
Old 08-01-2013 | 05:46 AM
Pete Bergstrom
Default RE: Evolution 15GX question
Matt,
We haven't seen this behavior in any of our testing. I would look into the following:
1. If you remove your on/off ignition switch from the battery/ignition loop (i.e. just plug directly into the battery pack) does this solve the problem? If it does, replace your switch. if not:
2. Pull your spark plug and see if you have an accumulation of carbon on the plug. The carbon might be retaining enough heat that the engine continues to run in a compression mode (ala a glow engine.) Clean any accumulated carbon from the plug and retry to see if this solves the problem. If there is an accumulation of carbon this is a good indicator you are running the engine a bit too rich.
Pete
