RE: ***CUB BROTHERHOOD***
Andreas,You are under powered, but if u wish to stick with the engine u have u gotta balance without the addition of so much weight. Although moving the engine forward might sound drastic its worth a try IMHO. My guess is that if you move it forward by placing a piece of mdf board or plywood behind the engine mount you may end up adding 250 gm only.Rafeek
