RE: Sig Spacewalker II 1/4 scale
I was sorry to miss Tuesday, but I had a laundry list of things Ihad to get done after work and just couldn't fit it in. I did make it out yesterday.
On soldering those threaded couplers, what are the steps? Do you do it like a bullet connector to an ESC wire where you tin the end of the wire/rod, then fill the coupler "cup" and finally heat the cup until the solder liquifies and plunge the rod in place? Or do you put the rod into the coupler first and then sweat the solder into it?
