RCU Forums - View Single Post - ARIXTRA Build Thread by ISAAC NAJARY
Old 08-01-2013 | 07:07 AM
  #319
najary's Avatar
najary
Default RE: ARIXTRA Build Thread by ISAAC NAJARY
ORIGINAL: gaRCfield
Hi Isaac,
When you fill the wing root (Post #151):
1) do you lube or do anything special to the plastic wrap?
2) are you using epoxy and microballoons? if so, is it finishing epoxy?
I have to fill the roots of my Integral. It is a composite wing so I was thinking of a wide bead of epoxy/microballoons or a wide bead of Hysol.
Thanks again for all of your work and information. I am learning a lot from you.
Best,
Joe
Hi Joe,
Sorry for the late answer.
1. I use some water with the plastic wrap.
2. I use structure epoxy with large quantity of microballoons see picture.
Best regards,
Isaac Najary
