RE: Distance judging
Normally, if I reduce a wing's angle of attack, the drag is reduced and the aeoplane goes faster.
So, why would reflex ... which reduces the wing's angle of attack ... be an exception to that?
I'm talking small angles, here, of course. If you reflexed the ailerons to say, 60 degrees, then clearly a load of drag would result.
