RCU Forums - View Single Post - spring starters
Old 08-01-2013 | 12:18 PM
bdtsr
Default RE: spring starters
If you have an electronic ignition such as a CH Ignition then a spring starter is dead weight. High idle, choke and ignition on, flip the prop until it pops, choke off and flip until it starts. If you have the stock CDI unit then yes a spring starter would be your best bet
