RE: Hangar 9 Taylorcraft 26cc Wing Tube???
OK, guys I need someone's help here please.... Is there any other plane out there or that you may have that uses a metal wing tube that is close to the same dimensions as the Taylorcraft> 21 1/2" long and 3/4" OD.... If it is longer I can cut it, if it is a little bigger OD I may be able to make it work.... Suggestions please...Thank you.
