RCU Forums - View Single Post - Hall Sensor specifications
Old 08-01-2013 | 02:09 PM
bluejets
Default RE: Hall Sensor specifications
It depends on your application as to which type of hall sensor to use.
If you can expand a little on how you intend to use it, it would be much easier and precise to suggest a particular unit.
Also, the hall effect is in itself a sensor, no need to add to the circuit for it to be operational other than to interface with whatever it is you are trying to achieve.
