RE: ZIROLI 98
wings (cont)
3-piece conversion (cont)
Last few things done for the evening.
Sanded the edges flush on the new bottom sheeting and checked that all wings are still aligned.
Ailerons:
Hard points added to the left aileron using scrap balsa blocks.
Trim tabs built up on the ailerons.
With all 'internals' done, the bottom sheeting was glued to the ailerons.
Flaps:
some end filler added using balsa scraps.
check offs:
To not miss any items to be done internally, I write/draw on the inside sheets everything that has to be done (at my age, I'd forget half the stuff!).
