RCU Forums - View Single Post - Prop Chart and Basic Electric Setup Sticky
Old 08-01-2013 | 10:29 PM
CafeenMan
Default RE: Prop Chart and Basic Electric Setup Sticky
If your plane has built-in right thrust then turning the prop the opposite direction will make the problem the right thrust was supposed to correct twice as bad. You'll need to use left thrust to fix it which is probably a nightmare if the plane is built. As has been suggested, just get a tractor prop.
