Engine thrust angles
I mount a prop, and set it horizontally. Then measure from each prop tip to some point in the middle, down the back end, like the base of the fin.
A bit of trig. will then give you the thrust angle.
Something like atan ((d1 - d2)/D
d1, d2 are the two distances you measured.
D is the prop diameter.
This may not be exactly accurate, but sin, tan and the actual angle
(in radians) will all be close to the same value for small angles.
