Thrust Angle
Phil, Thanks for the information. I've read of this technique before and feel it's a solid one to use. I also purchased a lazer incidence meter. Would it be accurate, using the kit plans, to measure the distance from the spinner back plate to the foward fuselage in order to come up with a measured distance as opposed to degrees of offset?
