RCU Forums - View Single Post - S-bus installation in Jets using non S-Bus servos
Old 08-06-2013 | 12:24 PM
schroedm's Avatar
schroedm
Guys,
I think several of you may be interested in the new Powerbox Powerbus system. Fully compatible with S-bus servos as standard and regular servos using a decoder box. Big difference is it using large cross section cable and MPX plugs for connections allowing much higher amps to be carried without worry.
I will see if I can post the manual for you..
