Originally Posted by
schroedm
Guys,
I think several of you may be interested in the new Powerbox Powerbus system. Fully compatible with S-bus servos as standard and regular servos using a decoder box. Big difference is it using large cross section cable and MPX plugs for connections allowing much higher amps to be carried without worry.
This is very interesting.......
A guy in my club did a S-Bus installation in a plane following the instructions 100%, and the result was a disaster. The power oscillation was huge and that was also affecting the turbine. He ended up doing a normal install.
I've always wondered why Futaba in the US offers something very different to what is being offered in Europe. In Europe they offer different cables and even a battery backer that can supply a steady voltage
EMCOTEC embedded controller technologies GmbH - Robbe/Futaba | S.Bus | S.Bus battery backer PSS 2018
Tons of different elements for an S-Bus install in that store but at the same time, it defeats the point of having a very simple system with S-Bus.
