I am trying to balance my hawk using the Easy Balancer in the pic below, My question is if anyone has used this balancer did you balance the plane right side up or up side down?
when I set my plane on the balancer at neutral and at 210 mm the nose is tilted up about 10 degrees, I think this is because the bottom surface of the wing has the wheel well offset ,the upper surface is more uniform,and would probably sit more evenly. would like to know what method others are using to balance,
J.C.
[ATTACH]1906018[/IMG]
