They were imported by Creek Hobbies in Mt. Holly, NJ. I have two of them--good flying planes. The first version had pink trim, the V2 had red trim, and the wingtips were cut back. The "chinakote" covering looks good until you breathe on it, then it starts coming off...
It's best described as a pattern/3D hybrid.
The fuse needs to be strengthened near the leading edge, 'cause if you don't do that, it will break! Also do NOT leave the canopy in direect sunlight, or it will quickly resemble a prune.....
Kevin
