Nickolay- I would recommend adding a plywood tab to your canopy base along with the associated slot / hole in the fuselage to accept a 3mm nylon bolt. (Tab on canopy will need 3mm blind nut as well.) If your latch is working, you only will need one nylon bolt. Since my plane has no latch, it needs two bolts, one on each side of canopy.
