RCU Forums - View Single Post - Can i put a washer behind my spinner backplate?
Old 08-10-2013 | 07:57 PM
jester_s1
Moderator
It's actually easier than gluing the sandpaper to get friction. Get some open mesh sandcloth that plumbers use or either the sanders for drywall that are open mesh. It is rough on both side and very coarse, so all you have to do is cut a piece to fit and make a hole for the prop shaft. I use this stuff for spinner that have the plastic backplate and it's nearly impossible for them to slip.
