Depending on how the thrust washer is attached to the engine you can put a spacer under the thrust washer to move it out. Some engines use a tapered collet and with that setup you can use a fairly thick washer. Some OS use the half crest to secure the thrust washer like the .46 I think you may be dealing with but can still be shimmed only to a lesser degree.
