Power = Drag x Velocity
Drag = Weight / (Lift Drag Ratio)
So if your aircraft size is doubled (wing span double = 4 times the original wing area), the weight could be 4 times the original (assuming same wing loading).
Assuming your Lift Drag ratio is the same, same cruise speed (same wing loading), then the power required will be 4 times.
