RCU Forums - View Single Post - Can i put a washer behind my spinner backplate?
Old 08-11-2013 | 06:34 PM
SeaJay
One of the problems I see with putting the spacer behind the engine mount instead of behind the spinner back plate is this. the cowl is cut specifically for the engine as it is currently mounted, if you put the spacer behind the engine mount, then the entire engine would move forward, and then the cowl opening might need to be enlarged. I think the spacer behind the spinner back plate would be much easier and cleaner option!
Craig.
