RCU Forums - View Single Post - A puzzling T-rex 600 issue!
Old 08-12-2013 | 09:43 AM
fly_inverted's Avatar
fly_inverted
Originally Posted by ATVAlliance
Did you notice if your tail blades are turning?
Yes, tail rotor works just fine. It is flyable, I only hear the noise when I accelerate quickly mid air.
Originally Posted by Kozzy_98
Gear Mesh between Motor and Main Gear is what could cause the noise.
That, and be sure to run soft start on your ESC
The ESC is on soft start. That is a possibility- I admit I know basically nothing about pinion gears. What would cause it to not mesh properly? I bought it used with a 14T in there and haven't touched it.
