with old timers we use bosch stick glue. the heat activated type, cheaper than the model a/c specific ones. thin it 50 :50 with acetone and paint onto the balsa surfacs you are covering, leave to dry (say 24 hours) and then apply covering as normal. problem you have is with glue growing old, aforementioned procedure soves same
