The smoke oil will work, but it has to be really pre heated with the smaller engines. You are going to need to plan the plumbing as you build the plane and have the pump and oil tank somewhere in the fuse. You are also going to need a high capacity battery for the pump. Gonna take some planning, so keep us posted on your progress. Good Luck, Dave
