Its not the switch. I did a copy set up with all different components!!
Different batteries, different switch, and different receiver and it worked fine under load .
Led did not flicker and I got a under load voltage reading. So it is not my hobbieco digital tester
It has something to do with the receiver. When I try just using the radio to operate everything seems fine???
