RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 08-15-2013 | 10:25 PM
  #1327
Dave Wilshere
Originally Posted by husafreak
Aw nuts! Came up about 4" short on 4mm turbine fuel line and had to place an order for more... Should be RTF in a couple weeks though.
As for the EDF good luck and I hope you can source a dependable ESC for 14s. It is just too EZ to burn up the big systems. Will you have full intake ducting for it?
No worries on ESC 250A Unit. Big thing about Schubeler is they know their stuff! 4 of these TP G8 packs give me 14s and 10,000mAh. ESC is never the worry, motor temp is everything. In developing the Spark I only blew motors...which took out the ESC each time. The guys in Germany fixed it soon enough.
No inlets, the inlet lip will smooth out air going it. I'm opening up everything for air intake, mainly on take-off. I can get the outlet within 5mm of what we want for the DS94 by removing the small lip at the back.
Dave
ID:	1908591   Click image for larger version
ID:	1908592   Click image for larger version
ID:	1908593   Click image for larger version
