well,i finally got to run my fastech tonight,conditions were perfect on Lake Ontario.first tank went by quick,carb was really rich,still performed admirably.when I brought it in,i noticed a large amount of water in the boat.checked lines from the head,found a split at the outlet fitting.cut and placed the line on the fitting.second run went about the same,still water in the hull.couldnt find a leak in the lines.third tank was going well,then it died.figured water was the cause.lots in the hull again after it was rescued.all in all,wasnt a bad experience,was impressed with handling of the boat.i guess I have some investigating to do to find the leak.i'll post a vid when I get it running decent.just wondering,would water temp effect the performance of the engine,as the water temp was approx. 65 degrees,and the head didn't feel too warm after running it.
