Originally Posted by
fireblade5437
Matt, black scheme looks good...
main fuselage painting is complete, so decided to make a set of new strobes (have cut the reflective tube different on this set which makes them a bit brighter than the original ones that I made (not that you could not see those) then I can start putting back the tube and turbine
Last pic the bright led caused the iPad camera to close right down, but up close about a couple of flashes is the most eyes can take before going wonky!
Alan
ps RCU slowly getting better, I found if you add pics with cursor after your last words then it will add as you can see here but if you have cursor in middle of text then your pics end up in that line of txt if that makes sense
As usual, beautiful work Alan.
