RCU Forums - View Single Post - ECHO 30.1 Chainsaw problem
Old 08-17-2013 | 02:05 PM
av8tor1977's Avatar
av8tor1977
Purge valve, primer bulb, same thing. It just pulls gas through the carb to fill it for initial starting and we normally don't use it on airplanes. Block off the fitting for the primer bulb, and just run the fuel inlet on the carb to your fuel tank. The fuel inlet on the carb is the one closest to the cast metal cover on the carb with one screw in it. That's the fuel pump. Then choke it, flip until you see fuel getting to the carb, and you should be good to go.
AV8TOR
