RCU Forums - View Single Post - Installing motor into esc on apprentice is tricky
Old 08-18-2013 | 06:29 AM
malitape's Avatar
malitape
My Feedback: (213)
Now that I understand the electrical setup, extending the wires between the esc and motor wires is probably the easiest.
Remember, never extend wires between battery and esc. You can use bullet connectors, however, if you can solder,
then that would be much better. The added advantage of extending those wires is to place the esc in a more ventilated
are of the plane. Good luck
