RCU Forums - View Single Post - Flashing Codes
Thread: Flashing Codes
Old 08-18-2013 | 11:09 AM
Chessiegolf
Default Flashing Codes
Ok Chaps,
Having succesfully upgraded my DV4 module to v2.63, I've now hit another problem.
I'm using a micro 10 receiver with gyro and its running on v2.50 (according to the release history there seems no reason to upgrade the receiver). All appears to be working normally on the ground (not flown since upgrade of Tx module) except that after about 30 secs from turning on the red Error LED flashes 3 on/ 1off. Having checked in Gigacontrol its definitely not a tx or rx battery threshold limit The expanation sheet for the flashing codes suggests that it is the gyro under recalibration, but the flashing just continues until I turn off the tx, prior to that the gyro appears to be doing what its supposed to.
Any suggestions please.
